[Gdal-dev] Re: GDAL Perl compilations
Ari Jolma ari.jolma at tkk.fi
Mon Apr 23 08:32:20 EDT 2007
Tamas Szekeres kirjoitti:
> Ari,
> Is the GDAL SWIG Perl compatible with ActivePerl + Visual Studio (nmake)
At the moment, no. For my part it is a problem of the things in
Makefile.PL because I've used it only with gcc (MinGW or Linux). But
that's only minor issue and it is easy to change, i.e. use .lib and not
.dll.a etc.
I'm currently trying to build it with ActivePerl & Visual C++ 2003, but
my first try yesterday was not succesful. I hit the same"
'PerlProc_abort' : is not a  member of '`global namespace" problem,
which is an issue with swig+MSVC I think. Currently I have no idea how
to fix that. Anybody?
I cc this to the list in case somebody has experience with ActiveState
Perl and Swig.
Ari
> I've tried this, but it did not work:
> E:\buildbot\osgeo\slaves\szekerest-msvc80-gdal\szekerest-vc80-quick\build\gdal\swig\perl>perl
> Makefile.PL
> Checking if your kit is complete...
> Looks good
> Warning: '-L../..' changed to
> '-LE:/buildbot/osgeo/slaves/szekerest-msvc80-gdal/szekerest-vc80-quick/build/gdal/swig/perl/../..'
> Note (probably harmless): No library found for -lgdal.dll
> Writing Makefile_Geo__OGR for Geo::OGR
> Looks good
> Writing Makefile_Geo__GDAL__Const for Geo::GDAL::Const
> Looks good
> Writing Makefile_Geo__OSR for Geo::OSR
> Looks good
> Writing Makefile_Geo__GDAL for Geo::GDAL
> E:\buildbot\osgeo\slaves\szekerest-msvc80-gdal\szekerest-vc80-quick\build\gdal\swig\perl>nmake
> -f Makefile_Geo__GDAL
> Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
> Copyright (C) Microsoft Corporation.  All rights reserved.
>        cl -c  -I../../gcore -I../../alg -I../../ogr -I../../port
> -nologo -GF -W3 -MD -Zi -DNDEBUG -Ox -GL -Wp64 -fp:precise -DWIN32
> -D_CON
> SOLE -DNO_STRICT -DHAVE_DES_FCRYPT -DWIN64 -DCONSERVATIVE
> -DNO_HASH_SEED -DUSE_SITECUSTOMIZE -DPERL_IMPLICIT_CONTEXT
> -DPERL_IMPLICIT_SYS -DU
> SE_PERLIO -DPERL_MSVCRT_READFIX -MD -Zi -DNDEBUG -Ox -GL -Wp64
> -fp:precise    -DVERSION=\"0.21\"  -DXS_VERSION=\"0.21\"
> "-IC:\Perl64\lib\CO
> RE"   gdal_wrap.cpp
> gdal_wrap.cpp
> gdal_wrap.cpp(359) : warning C4244: 'return' : conversion from
> '__int64' to 'int', possible loss of data
> gdal_wrap.cpp(1282) : warning C4267: 'argument' : conversion from
> 'size_t' to 'I32', possible loss of data
> C:\Program Files (x86)\Microsoft Visual Studio
> 8\VC\INCLUDE\cstdlib(20) : error C2039: 'PerlProc_abort' : is not a
> ace''
> 8\VC\INCLUDE\cstdlib(20) : error C2873: 'PerlProc_abort' : symbol
> cannot be used in a using-d
> eclaration
> 8\VC\INCLUDE\cstdlib(23) : error C2039: 'PerlProc_exit' : is not a
> ce''
> 8\VC\INCLUDE\cstdlib(23) : error C2873: 'PerlProc_exit' : symbol
> cannot be used in a using-de
> claration
> 8\VC\INCLUDE\cstdlib(23) : error C2039: 'PerlEnv_getenv' : is not a
> ace''
> 8\VC\INCLUDE\cstdlib(23) : error C2873: 'PerlEnv_getenv' : symbol
> eclaration
> 8\VC\INCLUDE\cstdlib(26) : error C2039: 'PerlMem_realloc' : is not a
> pace''
> 8\VC\INCLUDE\cstdlib(26) : error C2873: 'PerlMem_realloc' : symbol
> declaration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(26)
> : error C2039: 'PerlSIO_clearerr' : is not a member of '`global names
> pace''
> : error C2873: 'PerlSIO_clearerr' : symbol cannot be used in a using-
> declaration
> : error C2039: 'PerlSIO_fclose' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_fclose' : symbol cannot be used in a using-de
> claration
> : error C2039: 'PerlSIO_feof' : is not a member of '`global namespace
> : error C2873: 'PerlSIO_feof' : symbol cannot be used in a using-decl
> aration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(27)
> : error C2039: 'PerlSIO_ferror' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_ferror' : symbol cannot be used in a using-de
> claration
> : error C2039: 'PerlSIO_fflush' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_fflush' : symbol cannot be used in a using-de
> claration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(28)
> : error C2039: 'PerlSIO_fgetpos' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_fgetpos' : symbol cannot be used in a using-d
> eclaration
> : error C2039: 'PerlSIO_fopen' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_fopen' : symbol cannot be used in a using-dec
> laration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(29)
> : error C2039: 'PerlSIO_fputc' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_fputc' : symbol cannot be used in a using-dec
> laration
> : error C2039: 'PerlSIO_fputs' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_fputs' : symbol cannot be used in a using-dec
> laration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(30)
> : error C2039: 'PerlSIO_fread' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_fread' : symbol cannot be used in a using-dec
> laration
> : error C2039: 'PerlSIO_freopen' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_freopen' : symbol cannot be used in a using-d
> eclaration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(31)
> : error C2039: 'PerlSIO_fseek' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_fseek' : symbol cannot be used in a using-dec
> laration
> : error C2039: 'PerlSIO_fsetpos' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_fsetpos' : symbol cannot be used in a using-d
> eclaration
> : error C2039: 'PerlSIO_ftell' : is not a member of '`global namespac
> e''
> : error C2873: 'PerlSIO_ftell' : symbol cannot be used in a using-dec
> laration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(32)
> : error C2039: 'PerlSIO_fwrite' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_fwrite' : symbol cannot be used in a using-de
> claration
> : error C2039: 'PerlSIO_getc' : is not a member of '`global namespace
> : error C2873: 'PerlSIO_getc' : symbol cannot be used in a using-decl
> aration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(36)
> : error C2039: 'PerlLIO_rename' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlLIO_rename' : symbol cannot be used in a using-de
> claration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(37)
> : error C2039: 'PerlSIO_setbuf' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_setbuf' : symbol cannot be used in a using-de
> claration
> : error C2039: 'PerlSIO_setvbuf' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_setvbuf' : symbol cannot be used in a using-d
> eclaration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(38)
> : error C2039: 'PerlSIO_tmpfile' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_tmpfile' : symbol cannot be used in a using-d
> eclaration
> : error C2039: 'PerlLIO_tmpnam' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlLIO_tmpnam' : symbol cannot be used in a using-de
> claration
> C:\Program Files (x86)\Microsoft Visual Studio 8\VC\INCLUDE\cstdio(39)
> : error C2039: 'PerlSIO_ungetc' : is not a member of '`global namespa
> ce''
> : error C2873: 'PerlSIO_ungetc' : symbol cannot be used in a using-de
> claration
> : error C2039: 'PerlSIO_vprintf' : is not a member of '`global namesp
> ace''
> : error C2873: 'PerlSIO_vprintf' : symbol cannot be used in a using-d
> eclaration
> 8\VC\INCLUDE\xlocale(326) : warning C4530: C++ exception handler used,
> but unwind semantics a
> re not enabled. Specify /EHsc
> 8\VC\INCLUDE\xlocale(341) : warning C4530: C++ exception handler used,
> 8\VC\INCLUDE\xlocale(358) : warning C4530: C++ exception handler used,
> 8\VC\INCLUDE\streambuf(403) : error C2059: syntax error : '('
> 8\VC\INCLUDE\streambuf(432) : see reference to class template
> instantiation 'std::bas
> ic_streambuf<_Elem,_Traits>' being compiled
> 8\VC\INCLUDE\streambuf(403) : error C2059: syntax error : ')'
> 8\VC\INCLUDE\streambuf(403) : error C2143: syntax error : missing ')'
> before '->'
> 8\VC\INCLUDE\streambuf(403) : error C2143: syntax error : missing ';'
> before '->'
> 8\VC\INCLUDE\streambuf(404) : error C2334: unexpected token(s)
> preceding '{'; skipping appare
> nt function body
> 8\VC\INCLUDE\streambuf(436) : see reference to class template
>        with
>            _Elem=char,
>            _Traits=std::char_traits<char>
> before '->'
> before '->'
> nt function body
> 8\VC\INCLUDE\streambuf(437) : see reference to class template
>        with
>            _Elem=wchar_t,
>            _Traits=std::char_traits<wchar_t>
> before '->'
> before '->'
> nt function body
> 8\VC\INCLUDE\istream(1075) : warning C4530: C++ exception handler
> used, but unwind semantics
> are not enabled. Specify /EHsc
> gdal_wrap.cpp(1678) : warning C4244: '=' : conversion from 'IV' to
> 'long', possible loss of data
> gdal_wrap.cpp(2292) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(3288) : warning C4267: 'argument' : conversion from
> gdal_wrap.cpp(6572) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7021) : warning C4267: '=' : conversion from 'size_t' to
> gdal_wrap.cpp(7030) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7042) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7054) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7071) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7199) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7211) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7223) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(7240) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8214) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8226) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8515) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8527) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8539) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8661) : warning C4267: '=' : conversion from 'size_t' to
> gdal_wrap.cpp(8670) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8682) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(8694) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(9220) : warning C4244: '=' : conversion from 'IV' to
> 'short', possible loss of data
> gdal_wrap.cpp(9222) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(9224) : warning C4244: '=' : conversion from 'IV' to
> gdal_wrap.cpp(9226) : warning C4244: '=' : conversion from 'IV' to
> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio 8\VC\BIN\amd64\cl.EXE"' : return code '0x2'
> Stop.
> Best regards,
> Tamas
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
