[Gdal-dev] libgdal.so: open failed: No such file or directory
Mateusz Loskot mateusz at loskot.net
Mon Apr 23 12:55:33 EDT 2007
Gregory Yetman wrote:
> Mateusz Loskot wrote:
>> Gregory,
>> I've never worked on SunOS with GDAL, but if you have the 'ldd'
>> tool, please run:
>> ldd /absolute/path/to/gdalinfo
>> and paste the output here.
> Interesting, looks like it can't find libgdal.so:
> ldd /space/greg/sfw/gdal/gdal/bin/gdalinfo libgdal.so =>    (file not
> found)
Yes, that's what I supposed
> it exists in:
> /space/greg/sfw/gdal/gdal/lib
> I don't know why this would be the case....
Could you also check this:
echo $LD_LIBRARY_PATH
Perhaps my lack of knowledge of SunOS points to wrong direction,
and the LD_LIBRARY_PATH works differently under SunOS than under Linux,
but I'm inclined to say there the path with libgdal.so is not accessible
for the loader.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
