[Gdal-dev] Encoding in ogr2ogr
Richard Matsunaga richard.matsunaga at waypointinfo.com
Tue Apr 24 15:58:08 EDT 2007
Hi all,
I came across this post. I am having the same problem with a MapInfo tab
file with french accented characters. Other than the workaround provided by
Etienne, is there a way to solve this problem where more than just LATIN1
(or whatever) must be supported? i.e. without setting a system environment
variable.
Richard
On 12/11/05, Etienne Dube <etdube at globetrotter.net
<http://lists.maptools.org/mailman/listinfo/gdal-dev> > wrote:
> This is correct. I've managed to insert latin1 characters in a
> UTF8-encoded DB with ogr2ogr, by setting the PGCLIENTENCODING
> environment variable to LATIN1 (prior to running ogr). In Windows, that
> would be:
> SET PGCLIENTENCODING=LATIN1
Etienne / Charlie,
I have added a note on PGCLIENTENCODING in the postgres/postgis
driver details.  BTW, I am also getting "encouragement" from Andrey
to deal with encodings in OGR.  Perhaps something will need to be
done, as loath as I am to deal with it.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at
pobox.com <http://lists.maptools.org/mailman/listinfo/gdal-dev>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070424/9063dab3/attachment.html
