[Gdal-dev] Java and the build environment
Ari Jolma ari.jolma at tkk.fi
Wed Apr 25 13:43:52 EDT 2007
Andrea Aime kirjoitti:
> thanks for the heads up. In fact, the mingw installer downloaded and
> installed w32api and binutils for me once I asked for the g++ compiler
I think the default binutils is too old.
> c:\MinGW\bin\..\lib\gcc\mingw32\3.4.2\..\..\..\..\mingw32\bin\ld.exe:
> cannot find /c/progetti/gdal/gdalMing/frmts/o/.libs/EnvisatFile.o
I've got the same problem - now, after updating from trunk. The problem
is in .libs/libgdal.la.lnkscript which is created by libtool. If you
copy and paste the last command and replace it with frmts/o/.libs/*.o
port/.libs/*.o gcore/.libs/*.o alg/.libs/*.o o
gr/ogrsf_frmts/o/.libs/*.o ogr/.libs/*.o you should be able to run the
last command (providing there are no ogrinfo.o or similar in the
ogr/.libs/).
But the problem is with the libtool or something. The problem seems to
be only in MinGW. Damn.
Ari
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka
Geoinformation and positioning technology
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
