[Gdal-dev] Changes to libtool (or something) break MinGW build
Mateusz Loskot mateusz at loskot.net
Sat Apr 28 10:40:18 EDT 2007
Ari Jolma wrote:
> Ari Jolma kirjoitti:
>> Andrea Aime kirjoitti:
>>> c:\MinGW\bin\..\lib\gcc\mingw32\3.4.2\..\..\..\..\mingw32\bin\ld.exe:
>>>  cannot find
>>> /c/progetti/gdal/gdalMing/frmts/o/.libs/EnvisatFile.o
> this can also be fixed (assuming mingw is on C: drive) in libtool by:
> $ECHO "$obj" | sed -e "s/\/c\//c:\//" >> $output
> the | sed -e "s/\/c\//c:\//" has to be added by hand
> that's line 6114 at least in my libtool, just after "for obj in
> $save_libobjs"
> But the basic problem is probably a recent change somewhere which
> causes libtool to use full paths for _some_ of the object files that
> it writes into .libs/libgdal.la.lnkscript.
Ari,
I suppose this may be caused by ltmain.sh update a week ago:
http://trac.osgeo.org/gdal/changeset/11290
It's a big update to the libtool script.
Sorry, I feel a bit lost reading the magic of libtool script,
not sure if this is the problem.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
