[Gdal-dev] what is "band configurations"?
Sun Apr 29 12:43:16 EDT 2007
Maciej Sieczka wrote:
>> It states "Only Byte band types are supported, and only 1 and 3 band
>> configurations." in the Creation Options discussion.  This means you can
>> only create files with one band (treated as greyscale) and three bands
>> (treated as RGB).  Does that answer your question?
> Yes. Thanks. Could this extended info be added to JPEG spec as well as
> to JPEG section in GeoTIFF spec?
Maciek,
As long as you use PLANARCONFIG_SEPERATE (ie. INTERLEAVE=BAND) with the
GeoTIFF driver you can actually use jpeg compression with multi-spectral
data.  So I don't think this limitation applies to the geotiff driver.
I feel that the "and only 1 and 3 band configurations" is fairly clear
in the frmt_jpeg.html document especially in combination with the earlier
mention of only supporting greyscale and rgb.  Writing decent documentation
is a balance between adding enough detail, and avoiding obscuring things
with too much detail.  It is always hard to know where the right balance
is.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
