[Gdal-dev] Methods in the bindings that can easily create a segfault
Sun Apr 29 13:01:13 EDT 2007
Ari Jolma wrote:
> I've previously added a bunch of tests into the bindings. I wonder if I
> should do the same with these, or should I try to create typemaps that
> catch NULL parameters.
> I consider these serious problems since I believe Perl code should never
> cause a segfault. I have an graphical application, where any user can
> type in any Perl code. It is just not acceptable that such application
> segfaults.
Ari,
I'd be happy to have NULL checking, but I think the swig bindings is the
wrong place for it. I believe it should be done in the C API functions
instead.  My preference would be for you to backout any changes you have
made like:
   http://trac.osgeo.org/gdal/changeset/11367
And we instead do this comprehensively in the C API.  I'd be willing to
queue this up as a job for Matuesz in trunk (not 1.4 branch).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
