[Gdal-dev] Re: gdal_translsate color problem
Thu Aug 2 13:28:59 EDT 2007
Suray Ph wrote:
> Frank,
> Thank you for this response, this OK now.
> But if i add ... -co INTERLEAVE=TRUE TFW=TRUE ..., the output is also wrong!!
> The result image is grey.
> Could you give me an explanation?
Phillipe,
I'm afraid I will need access to the input file to test this myself.
Also, what viewer application are you using to determine the file is grey?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
