[Gdal-dev] problem translating ilwis-files and georeference
Thu Aug 2 13:35:43 EDT 2007
Christian.Strobl at dlr.de wrote:
> hi list,
> has anbody experiences with gdal_translate and ilwis? if i am using the
> following command
> gdal_translate.exe -of ILWIS file1.tif file2
> the resulting ILWIS-file has no georeference (no grf-file). what i am
> doing wrong.
> thanks for your help and greetings from munich
> christian
> p.s. file1 has the complete georeference imformation, for example:
Christian,
I just tried a similar translation on linux with a WGS84 georeferenced
file, and the .grf file was produced without any problem.  I'm a bit at
a loss as to why it isn't working at your end.
I have put my input file at:
http://download.osgeo.org/gdal/data/gtiff/small_world.tif
Hmm, interesting.  I tried the same translation on windows using FWTools
1.3.4 and it had the same problem (no grf file).  Well, this appears to be
a windows related problem.  I'd appreciate it if you could file a bug
report on this in Trac and I'll follow up with the ILWIS driver maintainer
and/or fix this myself.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
