[Gdal-dev] Building GDAL + JNI bindings using MinGW
Ari Jolma ari.jolma at tkk.fi
Fri Aug 3 11:13:46 EDT 2007
Frank Warmerdam kirjoitti:
> Regarding the original post, MingW is still not a supported GDAL
> platform,
> and so we don't make much effort to handle builds there.  We had
> discussed
> adding it a while ago but with Mateusz having less time than planned for
> general maintenance I think this is a bad time to add to his load.
I'm actively using GDAL that I compile with MinGW (MSYS in fact) so I'm
interested in keeping the build working in that environment also. I also
compile the Perl bindings in MinGW. However, I'm not including any other
drivers than the deafult ones - for example I've tried to include
JPEG2000 but failed.
Ari
