[Gdal-dev] FCC to gray scale
Ethan Alpert ealpert at digitalglobe.com
Mon Aug 6 14:34:10 EDT 2007
One more thing you may want to use the luminance formula instead of .33
to convert your imagery to grayscale. This is based on how humans
perceive color:
Y=0.3RED+0.59GREEN+0.11Blue
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ethan Alpert
Sent: Monday, August 06, 2007 12:28 PM
To: Todd Fagin; gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] FCC to gray scale
I just went through this process. You'll need to use the GDAL api. I
used the perl bindings. Attached is my script.
Hope this helps,
-e
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Todd Fagin
Sent: Monday, August 06, 2007 12:00 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] FCC to gray scale
Does anyone know of if there is a GDAL utility (such as gdal_translate)
that will allow you to go from a multi-band false color composite to a
grayscale?
Thanks,
Todd Fagin
Coordinate Solutions, Inc.
501 N.E. 15th St.
Oklahoma City, OK 73104
405.740.4324 (voice)
904.471.5548 (fax)
www.coordinatesolutions.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070806/1b767f27/attachment.html
