[Gdal-dev] Nodata bitmasks / null processing
Simon Perkins sy at perkins.net
Tue Aug 7 11:20:07 EDT 2007
So, would the default implementation return a universal RasterBand
derived class that implements IReadBlock() and IWriteBlock() in terms of
the underlying format RasterIO() method in conjunction with NODATA values?
There's a certain elegance to not duplicating a bunch of code that's
already in RasterBand. I guess the only drawback I can see would be if
RasterBand includes methods that don't really make any sense for
bitmasks. However, looking down the list of methods, I can't see
anything that's obviously out of place.
One thing though - if the GetBitmask() method is a RasterBand method,
then presumably invoking that method on a RasterBand returned by
GetBitmask() wouldn't make sense. Either this could just raise some kind
of error. Or we could make GetBitmask() a method of the Dataset instead.
Sy
Howard Butler wrote:
> Frank,
> I prefer Option 4, which is to treat bitmasks as just another
> RasterBand for each "data" RasterBand.  Something like
> bitmask = GetBand(1).GetBitmask()
> Why I like this approach:
>  - Familiarity to mentally challenged raster coders like myself.  I
> know how to work with a RasterBand.  I can make the mental leap to the
> bitmasks being a RasterBand with just on/off booleans.
> - Support for other language bindings with this approach is simple.
> - It would limit API additions.
> - Would it lessen some of the downsides of Option 3 (BitmaskIO)?
> I'll let others chime in on the downsides...
> Howard
> On Aug 4, 2007, at 12:06 PM, Frank Warmerdam wrote:
>> Folks,
>> Currently GDAL supports two mechanisms for identifying
>> nodata/transparent
>> areas in a raster.  One is use of a particular pixel value as a nodata
>> value (returned by the GDALRasterBand::GetNodataValue() method) and
>> the other
>> is by specifying an alpha band with alpha=0 marking transparent areas.
>> However, a number of file formats support a concept of "nodata masks" -
>> essentially bitmasks marking areas of the raster that are nodata
>> areas.  But
>> this is accomplished without having to reserve a special marker value
>> to be
>> the nodata value.
>> This is the case with GRASS for instance, and the GDAL GRASS driver
>> actually
>> jumps through hoops to promote byte data to int16 and overlay a
>> nodata value.
>> However, this is cumbersome and violates the underlying data model of
>> the
>> format.
>> This issue also arises with other formats, including a new JPEG
>> variation
>> with a nodata bitmask appended to the file.  I also feel that nodata
>> masks
>> can offer a better
>> A client has requested support for nodata bitmasking be incorporated
>> into
>> GDAL in some appropriate fashion.  I can see a few approaches:
>> 1) Pseudo-Alpha
>> In this approach the nodata mask is treated as a sort of alpha band with
>> values of 0 and 255.  One downside to this is that alpha bands are not
>> clearly associated with a particular band, so if you wanted to have
>> distinct nodata bitmasks for each band in a dataset there would be
>> no explicit association between particular alpha bands and particular
>> original bands.
>> 2) Data Promotion and NODATA pixel value creation
>> This is the approached used now in the GDAL GRASS driver.  A nodata
>> value
>> outside the current valid range is created within the driver, and if
>> necessary the pixel data type is promoted to a larger type to make space
>> for this "extra value" value.  For instance Byte pixel type would be
>> promoted to UInt16 so we could use 256 as our nodata value.
>> 3) Introduce Explicit Nodata Bitmap API
>> Extend the GDAL API to include an option for reading a validity bitmask
>> in the RasterIO() call - or perhaps a new BitmaskIO() method paralleling
>> the RasterIO() method.
>> Potentially the default implementation of this method could generate a
>> bitmask based on the raster data and nodata pixel values if they are
>> present so that applications could use this one method for both models.
>> In one sense this is the cleanest solution, but it is also by far the
>> most disruptive.  It requires new support in applications that want
>> to take advantage of it, further complicates the GDAL API and worst, it
>> may be very hard to implement properly for formats without bitmasks, but
>> with complicated resampling or blocking logic.
>> I am looking for some feedback from the community.  In particular I'm
>> interested in examples of file formats that include bit masking.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | President OSGeo,
>> http://osgeo.org
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
