[Gdal-dev] Nodata bitmasks / null processing
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 7 15:11:02 EDT 2007
Simon Perkins wrote:
>> I am wondering, a bit how we would represent the case where there is
>> one nodata bitmask for a whole dataset. That it, one mask applying
>> to all bands. Perhaps all bands just return the same object?
> Since users might be deleting the Bitmask RasterBand when they're done
> with it, it probably shouldn't be _exactly_ the same object, but it
> could be a copy of a stub that shares a lot of the underlying state /
> cache, etc. Might be worth adding a method "BitmaskType()" method
> returning NONE, ONE_PER_DATASET, or ONE_PER_BAND , or similar. This
> would also subsume the "HasBitmask()" method.
Simon,
Just as a datasource "owns" it's bands, and a band "owns" it's overviews,
I believe the band should "own" it's bitmask band object. So the
application should never try to delete the bitmask band object.
Nevertheless, the BitmaskType() might still be worthwhile.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
