[Gdal-dev] How to correct use GDALGCPTransform
Thu Aug 9 07:42:46 EDT 2007
Ivan Mjartan wrote:
> Hi, Frank and all .
> Thanks for previous reply. It helps me very much.
> So I was little bit testing and I found solution for me, I am using
> GDALGenImgProjTransform and virtual dataset like you said.
> It works fine but I have question Is it true when I use virtual datatset
> that whole raster is loading in to memory?
Ivan,
VRT rasters are not loaded all into memory.  Instead the VRT rasters
keeps a reference to the source raster and loads raster data from it
as it is requested from the VRT raster.
Best regards,
 > Maybe I have to save input
> raster into intermediate tiff file (to set GCP into input raster, it can
> be jpg or other), because my input can by very large, just when raster
> is loading whole.
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
