[Gdal-dev] Re: [whatever] toWGS defintions
Thu Aug 9 10:23:33 EDT 2007
Tomas R wrote:
> So for now I need to find a WKT for every projections I wish to support?
> To bad, for me, but hopefully I can get a big set of users to help me
> getting the correct WKT with a toWGS for their maps. I have two working
> now, RT90 and CH1903+. Working really good with no visible offset when
> drawing a GPS-track on the map.
> or wait for you to do what you *ought* to do :)
> No, that will not do.
> No tip on a source for WKT-strings? Perhaps one with all UTM-zones? Or
> one with the different projections used in Europe?
Tomas,
I mentioned geotools, right?  You should be able to use geotools to
build a set of WKT definitions for the EPSG coordinate systems though
whether they are the *best* TOWGS84 values would be questionable.
Some Java programming would likely be required.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
