[GDAL-dev] GEOS with GDAL
Mateusz Loskot mateusz at loskot.net
Sat Aug 11 13:34:35 EDT 2007
abhay menon wrote:
> I use the build for msvc80 in GEOS trunk to create the MSVC 8 compatible
> version which I am able to call in VC++6.
> I will let know on the problem that is being created on VC7.1. once I get
> time for that. And let you know what happened within.
FYI, I'm the author of the 'msvc80' project/solution for GEOS.
If you will notice any problems with that, please report it to me.
I'd like to keep this solution up to date and well working.
Thanks in advance.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
