[Gdal-dev] Re: Transformation from UTM32 WGS84 (EPSG:32632) to latlong (EPSG:4326)
WolfgangZ wollez at gmx.net
Mon Aug 13 04:30:39 EDT 2007
shortyII schrieb:
> Hi,
> thank you Wolfgang. Your solution works, but I had to edit the line
> <GeoTransform> 3.2256531250000000e+007...
> to
> <GeoTransform> 2.56531250000000e+005...
> Changing the line <DstRect xOff="-32000000" ... had no effect.
> Kind regards,
> Stefan
Sorry, you're right! It should have worked for creating a corrected UTM
file but not directly for warping.
Regards
Wolfgang
