[Gdal-dev] ECW->VRT->ECW
Dmitry Kan dmitry.kan at gmail.com
Mon Aug 13 09:28:34 EDT 2007
Hello, list!
I have a lot of ECW 10000x10000 rasters to be processed. I use VRT for
intermediate representation. After all things are done, I get an updated ECW
raster through CreateCopy().
When I try to process all the files at once I get:
ERROR 1: An error has occurred: Error 46 "Could not allocate enough memory"
file "" line 0
ERROR 1: IReadBlock failed at X offset 0, Y offset 2687
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 2687
I saw similar issue dated back to beginning of August (if correct). Was it
solved yet?
best wishes,
Dmitry Kan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070813/23fd0364/attachment.html
