[Gdal-dev] terchnical query
Sun Aug 19 19:49:44 EDT 2007
chenxuexia wrote:
>    hello,gdal teams.
>    Now i begin to  use gdal to develop a plugg-in for reading ArcGIS
> data. There's a field value showing like "2.3565E-06", and the field
> type  is displayed as float in ArcCatolog£¬also displayed as figure
> while export to dBase. But when i reading it in gdal, the field type is
> "OFTIntegerList", i wanna know :
> 1.  how and why do you store this "2.3565E-06" as an IntegerList?
Chenchen,
I cannot think of any reason an attribute on a shapefile
should be treated as an integer list.  Is this a shapefile
dataset?  Or perhaps SDE? E00? Arc/Info Binary Coverage?
> 2.  how can i reading field of this type into a CString object?
GetFieldAsString() should be suitable, though for integer lists
it may be truncated if the list is long.
> 3.  which types can be readed  by GetFieldAsString() function?
GetFieldAsString() should do something reasonable for all field
types, though in some cases the result is truncated.
I think you will need to provide a sample dataset demonstrating
the issue.  It might also be helpful to verify ogrinfo is
getting the same results you are finding.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
