[Gdal-dev] Status Report KML Driver
Jens Oberender j.obi at troja.net
Mon Aug 20 14:06:43 EDT 2007
Hi
As requested a status report for the kml driver as of today.
Working:
- reading and parsing the kml file works
- the vector part decides about what elements are layers and what features
- exporting simple Point layers/features (test with ogr2ogr into a shapefile,
only names are converted to fields yet)
Not yet implemented:
- exporting LineString and Polygon
- export with filters
- exporting more tags as fields
- get the layer extend
- special case handling (GeometryCollections)
Summary:
The base work is done, now the data can be handled and special cases need to
be detected and shipped around. I would guess about one week of work to
finish that.
Future:
The base (KML class) is written, so writing a child for rasters (analog to the
KMLvector class) shouldn't be too hard.
Bye
	Jens
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070820/ddfffaab/attachment.bin
