[Gdal-dev] NITF fixes
Tamas Szekeres szekerest at gmail.com
Wed Aug 22 04:29:51 EDT 2007
FYI Currently the autotest hangs on the nitf_1  test on any platform as of
Sat Aug 18 15:00 PDT
This problem causes the python.exe gets frozen on the windows builders
http://buildbot.osgeo.org:8500/
Best regards,
Tamas
2007/8/22, Frank Warmerdam <warmerdam at pobox.com>:
> Simon Perkins wrote:
> > Just in case anybody else is also having problems with this, I just
> > checked in some fixes to the GDAL NITF format directory to get it to
> > compile under visual studio again.
> > One of the problems was that some new code added earlier today in
> > nitffile.c used the strcasecmp() function, which is not available in
> > windows. I added a define that translates this to the equivalent
> > _stricmp() windows function if _MSC_VER is defined, but I wonder if
> > there's a more standard GDAL way to do this? Are these kinds of
> > incompatibilities handled by some cpl_ header file somewhere?
> Sy,
> The more common approach is to use the EQUAL() macro (which returns true
> if the strings are equal in a case insensitive way).
> Even, perhaps you could switch this? (assuming it was Even't recent work)
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
