[Gdal-dev] defragment files with gdal_translate in parallel
WolfgangZ wollez at gmx.net
Sat Aug 25 16:45:48 EDT 2007
I'm using gdal_translate to convert a remote dataset to a local one ;-)
Therefore I use several tiles in parallel. The local files are heavily
defragmented. I'm not sure if this is a WindowsXP problem or from gdal.
I'm using FWTools 1.3.5; had anybody the same experience?
Thanks
Wolfgang
