[Gdal-dev] HFD support?
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Aug 29 13:51:04 EDT 2007
Hi Mario,
GDAL does support Hdf 4 and 5. See:
http://www.gdal.org/formats_list.html
http://www.gdal.org/frmt_hdf4.html
http://www.gdal.org/frmt_hdf5.html
If you can't see it by running:
gdalinfo --formats
Is because the way your GDAL package was build.
HDF support is optional and requires the HDF4/5 dynamic libraries from
hdfgroup.org.
I think you should try the FWTools from maptools.org. It comes with a
pre-compiled GDAL distribution that support HDF4 and HDF5.
Ciao,
Ivan
Mario Cavicchi wrote:
> Hi to all,
> In this days i must to work with some HDF4/5 images from Modis.
> Unfortunately, GDAL don't supports this format.
> So i must to ask if, sooner or later, GDAL will support HDF.
> Tnx.
> PS: i'm always so sorry for my english.
