[Gdal-dev] HFA Driver behavior when spill file is present
Fri Aug 31 11:03:42 EDT 2007
Ozy Sjahputera wrote:
> Hi All,
> I just noticed a strange behavior of GDAL HFA driver.  Suppose you have
> an HFA file that is over 2GB in size.  This causes the creation of the
> spill (.ige) file. When you try to use Create() in GDALDriver class
> using the same name of the existing HFA file, instead of overwriting the
> pre-existing file GDAL simply appends more data to the spill file.  So
> you will end up with larger .ige file.  If I have a repeat process that
> uses the same filename, the .ige grows along with the process and it
> eats up the disk space unnecessarily, unless I specifically remove the
> old HFA file before creating a new one.
> Is there a way for me to just overwrite the old HFA image file when I
> create a new one?
> Thanks.
Ozy,
This is a bug - please file a bug report on it.  The HFA driver Create()
method really ought to delete the .ige file.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
