[Gdal-dev] loading metadata into NITF from separate image format
Sophia Parafina
sophia.parafina at ionicenterprise.com
Fri Aug 31 20:30:53 EDT 2007
Jared,
The NITF specs are available here:
http://www.gwg.nga.mil/ntb/baseline/format.html, they list the defined
tags for metadata in the header. I'm not sure what you mean by domain,
but I don't think there are nitf tags for sensor zenith or sun azimuth.
However, using gdal_translate use the -mo "tag=value" option to insert
the metadata. Yes, gdal_translate will write the metadata from a nitf to
a geotiff.
Cheers,
sophia
Jared Rubin wrote:
> I am inheriting from the RawDataset because it is scan line orientated and
> would like to stuff metadata like sensor zenith, sun azimuth, etc.. that are
> well defined metadata items in NITF and TIFF so that I can convert an
> internal image format to NITF or TIFF. Is there a specific domain that I need
> to use for NITF or TIFF for stuffing the metadata. If so can someone provide
> an example?
> In addition, if i was to stuff the metadata to NITF, would it carry over to
> TIFF?
> Basically if run gdal_translate from my internal format to NITF and then run
> gdal_translate from NITF to TIFF would the metadata carry over to TIFF?
> Thanks
> Jared
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
