[gdal-dev] Gdal_Translate Geotransform error
Tue Dec 4 10:06:52 EST 2007
Sundaram Subramaniam wrote:
> Dear Andrew
> i do have similar problem with gdal coordinate tranformation
> particularly with data georeferenced with geographic)lat/lon)
> coordinates. But it is Ok with map  GeoX/GeoY coordinates. Infact i
> could not even extract the values of geotransform from file with
> Geographic la/lon georeferenced. I think GDAL works only with projected
> map coordinates.
Sundaram,
GDAL supports projected and geographic datasets.  A geotransform is
potentially available in either case.  It may be that the geographic
dataset you did not get a geotransform for instead was georefenced
with ground control points.  A gdalinfo report on the dataset would
explain determine if that is the case.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
