[gdal-dev] Debug builds on Unix
Tue Dec 4 13:49:19 EST 2007
Ari Jolma wrote:
> Frank Warmerdam kirjoitti:
>> also reworked how debug builds are requested for GDAL on unix-like
>> builds.
>> While I don't especially love this approach, it seems to be inline
>> with unix
>> packaging standards and will hopefully make GDAL easier for folks to
>> use since
>> it works more like everything else.
> Why not have something like --enable-debug for configure? For example
> GTK seems to have that switch. What are these unix packaging standards
> that you refer to?
> I've always found it difficult to turn on the debugging since it's been
> through this environment variable.
Ari,
Andrey made the same suggestion, and I have incorporated support for
--enable-debug.  It will attempt to strip optimization flags out of the
CFLAGS and CXXFLAGS and add "-g -DDEBUG".  Skipping that and setting
CFLAGS and CXXFLAGS via the environment will also work as noted earlier.
Though I should mention I forgot to mention adding -DDEBUG without which
assertions will not be compiled in.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
