[gdal-dev] Python documentation help
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Dec 5 17:51:01 EST 2007
Howard,
It's all perfect now. I am glad to help.
 >>> import gdal
C:\Program Files\Python24\lib\site-packages\osgeo\gdal.py:90:
DeprecationWarning: gdal.py was placed in a namespace, it is now
available as osgeo.gdal
   DeprecationWarning)
 >>> gdal.AllRegister()
 >>> _
It warns and works!
 >>> from osgeo import gdal
 >>> gdal.AllRegister()
 >>> _
Works clean.
Best regards,
Ivan
Howard Butler wrote:
> On Dec 5, 2007, at 3:03 PM, Lucena, Ivan wrote:
>> Howard,
>> I thing I've got it!
>>> hmm... Where could it be picking up the old-gen gdal.py from?  The
>>> setup.py script in ./swig/python doesn't make reference to anything
>>> in ./pymod, the ./swig/python/gdal.py *is* the simple wrapper as
>>> expected, and setup.cfg doesn't point to ./pymod either.
>> My ./swig/python/gdal.py was wrong because it was generated by SWIG.
>> So I got the right gdal.py (with just a few lines) and I run setup.py
>> bdist_wininst again and everything is fine now. See:
>> >>> import gdal
>> C:\Program Files\Python24\lib\site-packages\osgeo\gdal.py:81:
>>  DeprecationWarning)
>> >>> gdal.AllRegister()
>> If I start over and compile SWIG Python then I've got the same problem.
>> I run:
>> cd swig
>> nmake -f makefile.vc python
>> And that re-creates the gdal.py. The bigger/wrong one.
>> Well, I hope that whole discussion would help you in some way... :)
> Ivan,
> Thanks, that was very helpful.  The windows makefile hadn't been updated
> to put its output in the osgeo directory and it was stomping over the
> simple wrappers.
> http://trac.osgeo.org/gdal/changeset/13266
> Howard
