[gdal-dev] Problem compiling the php swig bindings
Andreas Neumann a.neumann at carto.net
Thu Dec 6 11:26:26 EST 2007
Hello Frank and Nicol,
Thank you for your feedback. I guess I can use the gdal-tools from PHP
through system calls. So the need for the PHP bindings is not that urgent.
I can compile without. I can also try it with php-config and see what
works. Either way is fine for me.
Thank you both for your infos.
Andreas
> Andreas Neumann wrote:
>> Hello,
>> My make process of gdal-dev terminates due to an error when generating
>> the
>> PHP swig bindings. Am I missing some libraries or did something go wrong
>> with configure?
> Andreas,
> The php bindings have not been supported by anyone for a while and are no
> doubt badly broken.  Please avoid requesting them.
> I wonder if we should add some sort of warning somewhere about this -
> perhaps
> in the configure help strings for --with-php?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
