[Gdal-dev] WMS with C# Bindings
GrinderDev grinderprogrammer at gmail.com
Thu Dec 6 11:43:09 EST 2007
>The filename shouldn't matter. The thing that matters is that the first
>characters in the file are:
> <GDAL_WMS>
I verified that this was indeed the first characters in the file.
> Also, are you sure your GDAL library supports WMS requests?
I checked the library and it does indeed support WMS.  I'm using
FWTools2.0.2
Perhaps this is a C# binding issue?
View this message in context: http://www.nabble.com/WMS-with-C--Bindings-tf4956367.html#a14195862
Sent from the GDAL - Dev mailing list archive at Nabble.com.
