[Gdal-dev] WMS with C# Bindings
Tamas Szekeres szekerest at gmail.com
Fri Dec 7 18:40:20 EST 2007
Your file is working pretty good. The only thing I had to do is to set
the GDAL_DATA environment variable because of the EPSG specification.
You might want to do a test with gdalinfo, here's my command output:
E:\buildbot\osgeo\slaves\szekerest-msvc80-gdal\szekerest-vc80-full\build\gdal\apps>gdalinfo
--formats
Supported Formats:
  VRT (rw+): Virtual Raster
  GTiff (rw+): GeoTIFF
  NITF (rw+): National Imagery Transmission Format
  RPFTOC (ro): Raster Product Format TOC format
  HFA (rw+): Erdas Imagine Images (.img)
  SAR_CEOS (ro): CEOS SAR Image
  CEOS (ro): CEOS Image
  JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
  GFF (ro): Ground-based SAR Applications Testbed File Format (.gff)
  ELAS (rw+): ELAS
  AIG (ro): Arc/Info Binary Grid
  AAIGrid (rw): Arc/Info ASCII Grid
  SDTS (ro): SDTS Raster
  DTED (rw): DTED Elevation Raster
  PNG (rw): Portable Network Graphics
  JPEG (rw): JPEG JFIF
  MEM (rw+): In Memory Raster
  JDEM (ro): Japanese DEM (.mem)
  GIF (rw): Graphics Interchange Format (.gif)
  ESAT (ro): Envisat Image Format
  BSB (ro): Maptech BSB Nautical Charts
  XPM (rw): X11 PixMap Format
  BMP (rw+): MS Windows Device Independent Bitmap
  DIMAP (ro): SPOT DIMAP
  AirSAR (ro): AirSAR Polarimetric Image
  RS2 (ro): RadarSat 2 XML Product
  PCIDSK (rw+): PCIDSK Database File
  PCRaster (rw): PCRaster Raster File
  ILWIS (rw+): ILWIS Raster Map
  SGI (ro): SGI Image File Format 1.0
  SRTMHGT (rw): SRTMHGT File Format
  Leveller (rw+): Leveller heightfield
  Terragen (rw+): Terragen heightfield
  PNM (rw+): Portable Pixmap Format (netpbm)
  DOQ1 (ro): USGS DOQ (Old Style)
  DOQ2 (ro): USGS DOQ (New Style)
  ENVI (rw+): ENVI .hdr Labelled
  EHdr (rw+): ESRI .hdr Labelled
  GenBin (ro): Generic Binary (.hdr Labelled)
  PAux (rw+): PCI .aux Labelled
  MFF (rw+): Vexcel MFF Raster
  MFF2 (rw+): Vexcel MFF2 (HKV) Raster
  FujiBAS (ro): Fuji BAS Scanner Image
  GSC (ro): GSC Geogrid
  FAST (ro): EOSAT FAST Format
  BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
  LAN (ro): Erdas .LAN/.GIS
  CPG (ro): Convair PolGASP
  IDA (rw+): Image Data and Analysis
  NDF (ro): NLAPS Data Format
  DIPEx (ro): DIPEx
  ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
  ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
  PDS (ro): NASA Planetary Data System
  ERS (rw+): ERMapper .ers Labelled
  L1B (ro): NOAA Polar Orbiter Level 1b Data Set
  FIT (rw): FIT Image
  RMF (rw+): Raster Matrix Format
  WCS (ro): OGC Web Coverage Service
  WMS (ro): OGC Web Map Service
  MSGN (ro): EUMETSAT Archive native (.nat)
  RST (rw+): Idrisi Raster A.1
  INGR (rw+): Intergraph Raster
  GSAG (rw+): Golden Software ASCII Grid (.grd)
  GSBG (rw+): Golden Software Binary Grid (.grd)
  GS7BG (ro): Golden Software 7 Binary Grid (.grd)
  COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
  TSX (ro): TerraSAR-X Product
  COASP (ro): DRDC COASP SAR Processor Raster
  RIK (ro): Swedish Grid RIK (.rik)
  USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
  GXF (ro): GeoSoft Grid Exchange Format
  HTTP (ro): HTTP Fetching Wrapper
  ADRG (rw+): ARC Digitized Raster Graphics
GDAL_WMS.txt
ERROR 4: Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the
directory containing EPSG csv files.
ERROR 1: GDALWMS: Bad projection specified.
gdalinfo failed - unable to open 'GDAL_WMS.txt'.
E:\buildbot\osgeo\slaves\szekerest-msvc80-gdal\szekerest-vc80-full\build\gdal\apps>set
GDAL_DATA=E:/buildbot/osgeo/slaves/szekerest-msvc80-gdal/szekerest-vc80-f
ull/build/gdal/data
ps>
ps>gdalinfo GDAL_WMS.txt
Driver: WMS/OGC Web Map Service
Files: GDAL_WMS.txt
Size is 2666666, 1333333
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000135000033750,-0.000135000033750)
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left  (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
Upper Right ( 180.0000000,  90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
Center      (   0.0000000,   0.0000000) (  0d 0'0.01"E,  0d 0'0.01"N)
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Undefined
  Overviews: 1333333x666667, 666667x333333, 333333x166667, 166667x83333, 83333x4
1667, 41667x20833, 20833x10417, 10417x5208, 5208x2604, 2604x1302, 1302x651
Band 2 Block=1024x1024 Type=Byte, ColorInterp=Undefined
Band 3 Block=1024x1024 Type=Byte, ColorInterp=Undefined
Best regards,
Tamas
2007/12/7, GrinderDev <grinderprogrammer at gmail.com>:
> Adam Nowacki wrote:
> > You sure you're just not missing a 't' there? If not attach your xml
> > config file.
> The missing 't' was just a typing error.  Any other suggestions on getting
> this to work with C#?
> View this message in context: http://www.nabble.com/WMS-with-C--Bindings-tf4956367.html#a14214457
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
