[gdal-dev] Scripting OGR and KML
Brian Hamlin maplabs at light42.com
Sun Dec 9 16:01:41 EST 2007
I am new to scripting OGR, and for better or worse, I have chosen to
work with the Perl interfaces for now. I am writing a few test scripts
as part of the 1.5 testing phase.
You may be interested to know that the KML driver can be opened as a
Datasource, so writing to it effectively writes directly to KML from a
script.  KML is interesting because a) it is becoming widely accepted
in the various geobrowsers, and b) it simplifies the projection model
to a single case. It is essentially a simple display format.
So the Question is this:
  In OGR terms I see the Layer, Features and Geometry.. A Feature has a
FeatureDefinition.
  In KML terms, a Layer is a Folder, and Features are the Placemarks. I
can see by conversion testing that a Layer/Folder can have a name , and
Feature/Placemark can have a Name and a Description. The description
can be quite long.
   But using the class interfaces in a script, I dont see how to set
these things.  ???
   It looks like the name in a Feature Definition could be the name of a
Placemark. But that leaves Layer - Name, and Feature - Description ??
   pointers/insights appreciated
     -Brian
On Dec 7, 2007, at 6:56 PM, Lucena, Ivan wrote:
> Howard,
> I was helping someone that needed to use gdal2types.py from the latest
> distribution of FWTools and we got into trouble because Phyton 2.4
> couldn't find gdal_fw.dll even tough it was on the PATH. The reason
> for that is probably because the user doesn't had enough power to
> register environment variable during the running of the installer. I
> tried to set the PYTHONPATH on the command prompt but it didn't worked
> so we finally called the IT guy to re-install FWTools as administrator
> and it worked. Do you know exactly what is missing in a case like
> that?
> Best regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
