[Fwd: Re: [Gdal-dev] The perfect raster format - which is it?]
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Dec 11 12:18:54 EST 2007
-------- Original Message --------
Subject: Re: [Gdal-dev] The perfect raster format - which is it?
Date: Tue, 27 Nov 2007 12:19:09 -0800
To: Tim Sutton <tim at linfiniti.com>
CC: gdal-dev at lists.maptools.org
Hi Tim,
> Tiff is our second choice but the compression seems to require some
> kind of plugin in ArcMap so thats a bit of a bind...and the 4GB file
> size limit is sometimes hit due to inability to use compression  :-(
If you are using tiff with LZW compression, then the ESRI users prior to
ArcGIS v9.2 need the the LZW plugin, which used to cost money but is now
free (http://tinyurl.com/6l2q4 - HowTo: Use TIFF/LZW or GIF image files
in ESRI products now that the UNISYS patent for LZW has expired)
Packbits compession should work with all versions, though Arcview3 users
may need to enable one of the image reader extensions (installed by
default but not enabled, it's called "TIFF 6.0 Image Support").
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
