[gdal-dev] GDAL-1.5.0b2.win32-py2.5.exe install problems
Howard Butler hobu.inc at gmail.com
Tue Dec 11 13:27:09 EST 2007
Michael,
You need to have a gdal15.dll available in your path to use these.
Currently, the only way to get one is to build it yourself, but we
hope to have binaries available soon...
Howard
On Dec 11, 2007, at 11:12 AM, Michael ODonnell wrote:
> Has anyone had a chance to install the new release of the gdal
> windows installer. I tried to install it but I get an error when I
> import. Cannot find _gdal.
> Traceback (most recent call last):
>   File "<interactive input>", line 1, in <module>
>   File "C:\Python25\Lib\site-packages\gdal.py", line 2, in <module>
>     from osgeo.gdal import deprecation_warn
>   File "C:\Python25\Lib\site-packages\osgeo\gdal.py", line 7, in
> <module>
>     import _gdal
> ImportError: DLL load failed: The specified module could not be found.
> The file obviously exists so I am thinking there is a problem with
> the format or something.
> Howard and developer team, thanks for working on a gdal version for
> python 25. I have been trying to get an older version to work with
> python 2.5 and realized a lot of changes were required and it was a
> bit over my head at this time. Anyhow, thank you for the efforts.
> Michael
> Never miss a thing. Make Yahoo your homepage.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
