[gdal-dev] Re: ``HDF4Image: Can't get the list of geolocation maps in swath mod07''
Ivan Shmakov ivan at theory.asu.ru
Tue Dec 11 13:55:36 EST 2007
>>>>> Andrey Kiselev <dron at ak4719.spb.edu> writes:
 >> 1643      // Read geolocation data
 >> 1644      nDimMaps = SWnentries( hSW, HDFE_NENTMAP, &nStrBufSize );
 >> However, there `0' is returned...
 > Yes, and that is correct, because your HDF file does not contain
 > dimension maps, i.e. it is slightly broken dataset.
	ACK.
	BTW, I'm going to check GDAL vs. the MODIS datasets available at
	WIST [1].  I'll report the results here.
 > I should admit that I can't fix this thing without either serious
 > reworking the HDF-EOS library logic or hardcoding the workaround into
 > the driver (thing that I hate to do, because there are too many
 > variants of HDF-EOS products and our driver already full of such
 > things).
 > I have filled the bug report on this topic:
 > http://trac.osgeo.org/gdal/ticket/2079
 > Feel free to add yourself to CC: list to be informed on progress.
	ACK.
 > I am afraid that I will not be fixed in 1.5 branch.
	I probably will be able to maintain a locally patched version
	for the time being, if I'd come with any.  I need this
	functionality quite badly.
[1] http://wist.echo.nasa.gov/~wist/api/imswelcome/
