[gdal-dev] parallel processing
Lucena, Ivan ivan.lucena at pmldnet.com
Tue Dec 11 22:59:37 EST 2007
The HDFGroup's Parallel-HDF5 library is another good example of the use
of MPI-IO (Message Passing Interface) to implements parallel file
access, see:
http://hdf.ncsa.uiuc.edu/Parallel_HDF/PHDF5/ph5-status.html
James McManus wrote:
>>> Has implementing parallel process for GDAL and OGR been considered?
>> James,
>> There has not been much work on parallel processing within GDAL but
>> some applications do use GDAL in multiple threads at a time and there
>> has been considerable work to make aspects of GDAL thread safe.  In
>> particular modern GDAL should support a "many readers" situation fairly
>> well now as long as each of the readers is operating on distinct
>> GDALDataset objects.
>> For various reasons you can't have multiple readers active on a common
>> gdal dataset, and when GDAL is writing there should really only be
>> one thread active at a time.
>> Best regards,
> Frank,
> /That is basically what I am looking for. I would like to take advantage
> of my additional cores and CPU when I import data using v.in.ogr.  As
> you know large vector files take a long time to read, so it would be
> great if I could employ additional threads.  I searched the web to see
> if any other IO software was doing this. I found that netcdf has a
> library which uses MPI-IO:
> http://www-unix.mcs.anl.gov/parallel-netcdf/
> Reading spaghetti shape files into GRASS requires building of topology
> among other things. Multi-thread processing would speed this up
> dramatically. With the proliferation of multi-thread processors for PC's
> it seems like something that would eventually have to be incorporated
> into GDAL/OGR.
> Jim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
