[gdal-dev] Invalid GeoTransform
Wed Dec 12 16:29:45 EST 2007
Chris Howell wrote:
> I've got an NTF file that I am trying to open with GDAL 1.4.4. GDal is
> currently throwing an invalid Geo Transform (We don't supported skewed
> datasources). Is there any way using FW tools I can repair this
> transform to make it more GDAl friendly.
Chris,
It would be helpful to see a gdalinfo report on the problem file.
Generally speaking you can use gdalwarp to transform an image into a
north up, regularly grided image if the source is rotated, skewed, or
defined by control points.  Sometimes as simple as:
   gdalwarp in.ntf out.tif
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
