[gdal-dev] Trouble reading .dgn files
Roger André randre at gmail.com
Thu Dec 13 17:28:58 EST 2007
Ahhh soooo...
Yepp, these are definitely version 8 files.  I don't think I can give you
one of the files I'm getting the error with, but I'll see if I can get a
dummy one made with the same tools for you to test with.
Thanks,
Roger
On Dec 13, 2007 11:08 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Roger André wrote:
> > I'm having trouble reading .dgn files using the ogr utilities and can't
> > figure out what I'm doing wrong.  I've tried to read the data a number
> > of different ways:
> > ogrinfo ./ D3460_PFA_RDNew.dgn
> > ogrinfo -all ./ D3460_PFA_RDNew.dgn
> > ogrinfo -all ./ D3460_PFA_RDNew.dgn elements
> > ogrinfo ./ D3460_PFA_RDNew.dgn elements
> > ogrinfo -summary ./D3460_PFA_RDNew.dgn elements
> > ogr2ogr -f "ESRI Shapefile" test.shp ./D3460_PFA_RDNew.dgn
> > ogr2ogr -f "ESRI Shapefile" test.shp ./D3460_PFA_RDNew.dgn elements
> > The .dgn format is new to me, so if anyone could give me advice on how
> > best to work with it using the GDAL libs, I'd very much appreciate it.
> Roger,
> My first guess would be that these are v8 or newer dgn files.  OGR only
> supports the older v7 and earlier format.  What error message are you
> getting?  Can you make one of the dgn files available for review?
> I'd like to have OGR report a meaningful error for new files if that
> is the problem.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071213/2139bfa0/attachment-0001.html
