[gdal-dev] Re: gdal_translate: a preliminary `-gcp_file' patch
Ivan Shmakov ivan at theory.asu.ru
Sun Dec 16 03:30:33 EST 2007
>>>>> Frank Warmerdam <warmerdam at pobox.com> writes:
 >> Since the current version of GDAL doesn't support reading GCPs from
 >> some of the data sets I use [1], I have to use `gdal_translate' to
 >> specify all the GCPs, like:
 > Ivan,
 > The --optfile was already mentioned.
	Yes, `--optfile' may suit my needs.  However, I'm having some
	considerations regarding `-gcp' and the GDAL CLI in general that
	I'll present separately.
 > I just wanted to add that there are dangers to trying to attach large
 > numbers of GCPs to a GeoTIFF image.  Some sort of problem with the
 > maximum tag size I believe.
	The output format doesn't matter to me now.  If there's an other
	format suitable for storing GCPs with `gdal_translate', I could
	easily switch to it.
 > So translating full density geolocation arrays to GCPs is likely to
 > cause a variety of problems.
	Actually, I wonder, whether a lot of GCPs would cause any
	problems with `gdalwarp'?
	BTW, `hdfdump' (which I've used in the original post's example)
	supports dumping a sparse subset of the HDF4 field, so it's not
	really a problem to make a file with sparse GCPs.
 > One approach is to subsample them.  Another is to treat them as
 > geolocation arrays in the sense described in:
 > http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
	Isn't it more appropriate for HDF-EOS GCPs to be represented as
	specified there?
	Is there any way to convert ``ordinary'' GCPs into RFC 4 GCPs
	and vice versa?
