[gdal-dev] Information about GDAL JP2Kakadu supported datatypes
Daniele Romagnoli dany.geotools at gmail.com
Mon Dec 17 13:09:07 EST 2007
Hi list,
I have a very simple question for you :)
Which data types are supported as input of the JP2K driver based on Kakadu?
Looking at jp2kakdataset.cpp I noticed the presence of an if-else chain
which checks the bit_depth of the codestream. (supporting signed 16 bit
bands, unsigned 16 bit, float 32 bit and bytes).
How other datatypes are treated? (I mean, as an instance, a 3 bands image
with 12bits for each band).
Finally, which datatypes may be written to a JP2K file?
Thank you very much.
Best Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071217/7bc7696d/attachment.html
