[gdal-dev] HDF-EOS vs. GDAL: order of dimensions
Lucena, Ivan ivan.lucena at pmldnet.com
Tue Dec 18 09:02:16 EST 2007
Andrey,
Andrey Kiselev wrote:
> I would like to have the last option implemented. This requires addition
> of the open option concept to raster core of GDAL.
Can we add the user-defined dimension request to the end of the
subdataset name string?
HDF4_SDS:subdataset_type:file_name:subdataset_index:user-defined-dimension
Ex:
gdalinfo HDF4_SDS:MODIS_L1B:my-hdf-file.hdf:2:134x2040
That will not require any changes in the GDALOpen() API.
Regards,
Ivan
