[gdal-dev] Future of PHP bindings
Mateusz Loskot mateusz at loskot.net
Thu Dec 20 17:06:40 EST 2007
Daniel Morissette wrote:
> Mateusz,
> I presume the PHP bindings you are referring to are some SWIG-generated
> bindings, right?
Daniel,
Yes, gdal/swig/php mentioned as not maintained, on the Wiki:
http://trac.osgeo.org/gdal/wiki/GdalOgrInPhp
> In case anyone is interested, we had also built a while ago a php_ogr
> extension (hand made). I have not tested it myself with GDAL 1.5, but it
> may still work or be easy to port if anyone needs it.  The source and
> documentation for that php_ogr module are available at:
> http://dl.maptools.org/dl/php_ogr/
Perhaps you could drop a note about it to the Wiki page?
> Actually, I think a copy of the php_ogr.dll is included in MS4W, so the
> module must still work with recent GDAL releases.
Ah, so if this is the same, then MS4W is mentioned on the Wiki.
Although, if you see there is anything (URLs, notes) missing,
I'd be thankful if you could updated it so there is a place we can
direct users interested in PHP bindings. Thanks in advance.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
