[gdal-dev] GDAL 1.5, TileService and TileCache
Guillaume Sueur guillaume.sueur at neogeo-online.net
Fri Dec 21 11:19:54 EST 2007
I can't use TileCache because the client doesn't want to add mod_python
to his apache...
So, I'm looking for a way to generate tiles from a WMS server and use
them locally.
Thanks for your answer, and happy holidays for all of you !
Guillaume
Klokan Petr Přidal a écrit :
> Hi Guillamume,
> For what you are describing I would recommend you to use project
> TileCache http://www.tilecache.org/.
> I don't know what you mean with "new GDAL TileService".
> There is a new
>  - WMS read only GDAL driver (Google SoC: Adam Nowacki) that supports
> reading of remote sources like WMS, WMS-C and WorldWind's TileService.
>  - GDAL2Tiles tool (Google SoC: me), which generate TMS tiles with
> simple html viewers and eventually KML for Google Earth.
> Yes, TileService is WorldWind only, TMS (OSGeo TileMapService) is more general.
> If you are interested in available tile formats, standard tile
> projections etc. look at links from document
> http://spreadsheets.google.com/pub?key=pm3_jKEJCJ2e2wiIfjdBABg
> If I get it correctly your first idea was:
> By a GDAL command line tool (like gdal2tiles.py) generate static tiles
> from a remote WMS server and use that static tiles instead of
> TileCache project?
> I think this will not run for now - especially for global
> (geodetic/mercator) tiles, because GDAL2Tiles do not support yet TMS
> global profiles. It is planned. Then it could run this way I hope, if
> the new WMS driver allow correct read of a remote raster.
> Adam Nowacki:
> Would it be hard to add support for reading remote TMS tiles generated
> by GDAL2Tiles (link to TileMapResource.xml is enough I hope) and
> probably also for Zoomify tiles (I did prototype in python for zoomify
> tiles download script, which could be used as inspiration - look at
> http://www.staremapy.cz/zoomify-analyza/).
> The reason for this is that we need to rectify (by gdalwarp) remote
> tiles - usually old maps published by libraries.
> Idea is that one person publish the map without georeference as
> TMS/Zoomify tiles, and somebody else can rectify it later by an online
> tool similar to Metacarta Rectifier.
> Merry x-mas to everybody
> Klokan
> On Dec 21, 2007 10:39 AM, Guillaume Sueur
> <guillaume.sueur at neogeo-online.net> wrote:
>> Hi,
>> Hope I'm in the good list, didn't find any gdal-users list...
>> I'm very interested in the new GDAL TileService and have a few questions
>> about it. Can it act as TileCache, retrieving tiles from some remote WMS
>> server and caching those tiles locally ? Reading the doc makes me think
>> yes, but TileService seems to be specific for WorldWind...
>> Any clue ?
>> Thanks
>> Guillaume SUEUR
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
