[gdal-dev] gdal install problem
hjc520070 hjc520070 at 163.com
Sat Dec 22 09:36:58 EST 2007
I download the file "gdalwin32-1.4.4" ,Then Unzip it and add the gdalwin32-1.4.4\bin directory to your PATH. Finally,define the GDAL_DATA environment variable to point to gdalwin32-1.4.4\data directory.
My platform is windows. python 2.5 is availabel in my computer.
However it doesn't work. Is there anything esle I should do to make it work properly.
Thank you for your help.
               cong
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071222/c75a0f68/attachment-0001.html
