[gdal-dev] Testing if two spatial references are the same
Simon Perkins sy at perkins.net
Wed Dec 26 15:23:43 EST 2007
I have a file, which is giving me some strange results with the
OGRSpatialReference.IsSame() method. Here's a short test program:
#include "gdal_priv.h"
#include "ogr_spatialref.h"
#include "ogr_core.h"
#include <iostream>
using namespace std;
int main(int argc, char** argv)
    GDALAllRegister();
    const char* filename = argv[1];
    GDALDataset* dataset = (GDALDataset*) GDALOpen(filename, GA_ReadOnly);
    cout << "Opened file: " << filename << "\n";
    const char* projWkt = dataset->GetProjectionRef();
    cout << "Raw Projection WKT: " << projWkt << "\n";
    OGRSpatialReference* spatialRef = new OGRSpatialReference(projWkt);
    char* prettyWkt = new char[4096];
    spatialRef->exportToPrettyWkt(&prettyWkt, 0);
    cout << "Pretty Projection WKT:\n" << prettyWkt << "\n";
    cout << "Result from s.IsSame(s): " <<
spatialRef->IsSame(spatialRef) << "\n";
    return 0;
Basically, the code opens a raster file, grabs the projection Well Known
Text string, constructs an OGRSpatialReference using that string, and
then compares that spatial reference to itself using the IsSame()
method. One would expect that a spatial reference is the same as itself,
so this method should return 1.
Here's the output from a particular file:
Opened file: C:/Images/Demo/K10.tif
Raw Projection WKT:
PROJCS["unnamed",GEOGCS["NAD83",DATUM["North_American_Datum_
1983",SPHEROID["GRS
1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AU
THORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],UNIT["US survey
foot",0.3048006096012192,AUTHORITY["EP
SG","9003"]],AUTHORITY["EPSG","26942"]]
PROJCS["unnamed",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
            AUTHORITY["EPSG","6269"]],
    UNIT["US survey foot",0.3048006096012192,
        AUTHORITY["EPSG","9003"]],
Result from s.IsSame(s): 0
Any ideas what's going on here? Is it something specific to this
particular projection string? Is there a better way of checking
equivalence of projected coordinate systems, e.g. using the EPSG code?
What would I have to check to ensure equivalency?
Regards,
Simon
