[gdal-dev] problem w/ libexpat while compiling 1.5.0 on 64-bit RHEL 5
John Cartwright John.C.Cartwright at noaa.gov
Wed Dec 26 17:12:18 EST 2007
Hello All,
I'm having a little trouble compiling 1.5.0 on my 64-bit Red Hat
Enterprise Linux 5.1.  The issue seems to be that, regardless of my
attempts to influence it, configure insists on getting the libexpat.so
from $ORACLE_HOME and complains that the "File in wrong format".
I've tried using the RedHat-provided expat library (both 32 and 64 bit
versions), and built a new local copy of expat.  My configure includes
the lines:
--with-expat-inc=/extra/contrib/expat-2.0.1/include \
 --with-expat-lib=/extra/contrib/expat-2.0.1/lib \
but I still see lines like the following during the make, suggesting
that the correct expat library is not being found:
libtool: link: g++ -shared -nostdlib
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbeginS.o
.libs/libgdal.la.lnkscript  -Wl,-rpath -Wl,/extra/contrib/geos-2.2.3/lib
-Wl,-rpath -Wl,/extra/contrib/oracle/product/10.2.0/db_1/lib -Wl,-rpath
-Wl,/extra/contrib/libdap-3.7.8/lib -Wl,-rpath
-Wl,/extra/contrib/geos-2.2.3/lib -Wl,-rpath
-Wl,/extra/contrib/libdap-3.7.8/lib -L/extra/contrib/geos-2.2.3/lib
/extra/contrib/geos-2.2.3/lib/libgeos_c.so
/extra/contrib/geos-2.2.3/lib/libgeos.so -lsqlite3
-L/extra/contrib/oracle/product/10.2.0/db_1/lib -lclntsh -lnnz10 -lodbc
-lodbcinst -L/usr/lib
/extra/contrib/oracle/product/10.2.0/db_1/lib/libexpat.so
-L/extra/contrib/xerces-c-2.7.0/lib -lxerces-c
-L/extra/contrib/netcdf-3.6.2 -L/extra/contrib/netcdf-3.6.2/lib
/extra/contrib/netcdf-3.6.2/lib/libnetcdf.a -L/usr/lib64 -lpq -lrt
-L/extra/contrib/lib -L/extra/contrib/libdap-3.7.8/lib
/extra/contrib/libdap-3.7.8/lib/libdapserver.so
/extra/contrib/libdap-3.7.8/lib/libdapclient.so -L/usr/kerberos/lib64
/extra/contrib/libdap-3.7.8/lib/libdap.so -lxml2 -lpthread -lcurl
-lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lresolv -ldl -lidn
-L/usr/lib64/mysql -lmysqlclient -lz -lcrypt -lnsl -lssl -lcrypto
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
-L/lib/../lib64 -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtendS.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
-Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.0
The LD_LIBRARY_PATH variable has been unset. Can someone give me advice
on how to work around this situation?
Thanks!
-- john
