[gdal-dev] GDAL 1.5.0 (RC2) Binaries
Howard Butler hobu.inc at gmail.com
Thu Dec 27 12:33:55 EST 2007
On Dec 26, 2007, at 11:00 PM, mchapman at texelinc.com wrote:
> Howard,
> Thank you very much for that information.
> So, then I assume that a good client process of gdalxx.dll would
> ensure that the dependencies of the gdal plugins are correctly in
> the path and would resolve any issues before gdal is loaded?
I'm not quite sure what you mean by a good client process, but I'll
assume you mean an application that embeds GDAL within it.  If it were
possible to programatically do something like depends.exe to walk
everything, I guess that would be one way to do it.  Does anyone know
of code out there that does something like this?  It'd be handy in a
number of contexts...
> Could this be done by removing the plugin dll from the plugin
> directory if the dependency path could not be validated?
Yes, if a plugin dll is not in the anointed directory, GDAL should not
attempt to load it.
Howard
