[gdal-dev] GDAL 1.5.0 (RC2) Binaries
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Dec 27 15:31:30 EST 2007
Howard,
That tool, Performance Monitor is the old File Monitor that Microsoft
bought and is giving away for free:
"FileMon monitors and displays file system activity on a system in
real-time. Its advanced capabilities make it a powerful tool for
exploring the way Windows works, seeing how applications use the files
and DLLs, or tracking down problems in system or application file
configurations."
[http://technet.microsoft.com/en-us/sysinternals/bb896642.aspx]
It might help...
Since any application can change the environment variables at anytime
during the execution it is hard to know what is been loaded and from
where. I was luck once to load the GDAL project in VC2003 and run a
binary commercial application and track the GDAL plug-in loading process
in debug mode.
It might work too.
Best regards,
Ivan
Howard Butler wrote:
> On Dec 26, 2007, at 11:00 PM, mchapman at texelinc.com wrote:
>> Howard,
>> Thank you very much for that information.
>> So, then I assume that a good client process of gdalxx.dll would
>> ensure that the dependencies of the gdal plugins are correctly in the
>> path and would resolve any issues before gdal is loaded?
> I'm not quite sure what you mean by a good client process, but I'll
> assume you mean an application that embeds GDAL within it.  If it were
> possible to programatically do something like depends.exe to walk
> everything, I guess that would be one way to do it.  Does anyone know of
> code out there that does something like this?  It'd be handy in a number
> of contexts...
>> Could this be done by removing the plugin dll from the plugin
>> directory if the dependency path could not be validated?
> Yes, if a plugin dll is not in the anointed directory, GDAL should not
> attempt to load it.
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
