[gdal-dev] Setting up a StatePlane Coordinate system
Martin Chapman mchapman at texelinc.com
Fri Dec 28 14:55:35 EST 2007
Christiaan,
Can you send me your projection string and I will validate the projection is
correct and then I will send back the code I used to do it.
Martin Chapman
Chief Software Architect
Fortified Datacom Inc.
http://www.fortifieddatacom.com
mchapman at fortifieddatacom.com
303-324-1065
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Christiaan Janssen
Sent: Friday, December 28, 2007 12:32 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Setting up a StatePlane Coordinate system
Could someone point me to (or provide me) a code snippet that shows how one
would go about setting up a State Plane zone based OGR Spatial Reference
object. Every attempt I've made has resulted in a SRS object that when used
with OGRCreateCoordinateTransformation() function always results in a
failure because there is no conversion from it. Thanks
Christiaan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071228/5941aecb/attachment.html
