[gdal-dev] Proj4 makefile.vc
Mateusz Loskot mateusz at loskot.net
Sat Dec 29 06:25:05 EST 2007
Martin Chapman wrote:
> Frank / Anyone,
> I don't know if this correct but I was having trouble getting the proj.dll
> to load in my MFC exe application in VS2005 in debug mode MDd.  I went into
> the makefile.vc for proj and changed the following to match your nmake.opt
> compiler settings for debug and now everything works great.  I would imagine
> that is ok to do?  This is what I changed it to be:
> #OPTFLAGS=  /nologo /Zi /MD /Fdproj.pdb
> OPTFLAGS=   /nologo /MDd /EHsc /Zi /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE /DDEBUG /D_DEBUG /Fd$(PROJ_LIB_DIR)\Fdproj.pdb
Martin,
These debug flags is a kind of minimal required set of flags and
do not include all necessary flags between Visual C++ versions.
AFAIU, it's intentional to leave customization of OPTFLAGS to a user.
Your version of flags looks correct to me, for Visual C++ 8.0 (2005).
BTW, I believe this post belongs to proj list than gdal-dev,
so I've added it to CC.
http://lists.maptools.org/mailman/listinfo/proj
Cheers
Mateusz Loskot
http://mateusz.loskot.net
